Ir para o conteúdo principal
Insignia Flex 11.6 Motherboard Replacement
O que você precisa
  1. Insignia Flex 11.6 Motherboard Replacement, Power Removal: passo 1, imagem 1 %32 Insignia Flex 11.6 Motherboard Replacement, Power Removal: passo 1, imagem 2 %32 Insignia Flex 11.6 Motherboard Replacement, Power Removal: passo 1, imagem 3 %32
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Motherboard Replacement: passo 2, imagem 1 %32 Insignia Flex 11.6 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. How to Remove a Stripped Screw
  3. Insignia Flex 11.6 Motherboard Replacement: passo 3, imagem 1 %32 Insignia Flex 11.6 Motherboard Replacement: passo 3, imagem 2 %32 Insignia Flex 11.6 Motherboard Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Motherboard Replacement: passo 4, imagem 1 %32 Insignia Flex 11.6 Motherboard Replacement: passo 4, imagem 2 %32 Insignia Flex 11.6 Motherboard Replacement: passo 4, imagem 3 %32
    Comprar
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Unplug the 2 speaker's connection from the motherboard.
  6. Insignia Flex 11.6 Motherboard Replacement: passo 6, imagem 1 %32 Insignia Flex 11.6 Motherboard Replacement: passo 6, imagem 2 %32
    • Peel the yellow tape off from on top of the electrical connectors.
  7. Insignia Flex 11.6 Motherboard Replacement: passo 7, imagem 1 %32 Insignia Flex 11.6 Motherboard Replacement: passo 7, imagem 2 %32
    Comprar
    • Flip up the black cover pieces to expose the 3 electrical connectors.
    • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  8. Insignia Flex 11.6 Motherboard Replacement: passo 8, imagem 1 %32 Insignia Flex 11.6 Motherboard Replacement: passo 8, imagem 2 %32 Insignia Flex 11.6 Motherboard Replacement: passo 8, imagem 3 %32
    • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
    • Remove the black camera connector by gently prying on it until it unhooks.
  9. Insignia Flex 11.6 Motherboard Replacement: passo 9, imagem 1 %32 Insignia Flex 11.6 Motherboard Replacement: passo 9, imagem 2 %32
    • Using tweezers, remove the microphone from the the plastic cover.
  10. Insignia Flex 11.6 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
    • Motherboard pops out.
Conclusão
2 comentários
This looks great. Can you provide more detail on Step 3 (opening the case?) Are there locking tabs that I need to worry about breaking? And if so, how many? Does the cover simply snap back into place?
I need to open my unit simply to disconnect the power to clear the BIOS. I stupidly disabled my USB ports and there is no way to navigate the BIOS without the (USB) keyboard (how freaking dumb is that!)
Mugsys RapSheet - Responder
Very nicely done. Do you suppose that the SSD can be upgraded to something larger?
Curtiss Riedel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 2,470
