Ir para o conteúdo principal
Insignia Flex 11.6 Battery Replacement
O que você precisa
  1. Insignia Flex 11.6 Battery Replacement, Battery: passo 1, imagem 1 %32 Insignia Flex 11.6 Battery Replacement, Battery: passo 1, imagem 2 %32 Insignia Flex 11.6 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
  2. Insignia Flex 11.6 Battery Replacement: passo 2, imagem 1 %32 Insignia Flex 11.6 Battery Replacement: passo 2, imagem 2 %32
    • Remove the two 6.1 mm Phillips J000 screws from the bottom of the device. Use Phillips Screwdriver size J1.
    • If any screws are stripped, refer to the iFixit guide for how to remove a stripped screw.
  3. Insignia Flex 11.6 Battery Replacement: passo 3, imagem 1 %32 Insignia Flex 11.6 Battery Replacement: passo 3, imagem 2 %32 Insignia Flex 11.6 Battery Replacement: passo 3, imagem 3 %32
    • Using a plastic opening tool, gently pry off the back cover.
  4. Insignia Flex 11.6 Battery Replacement: passo 4, imagem 1 %32 Insignia Flex 11.6 Battery Replacement: passo 4, imagem 2 %32 Insignia Flex 11.6 Battery Replacement: passo 4, imagem 3 %32
    • Remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Battery Replacement: passo 5, imagem 1 %32 Insignia Flex 11.6 Battery Replacement: passo 5, imagem 2 %32 Insignia Flex 11.6 Battery Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Make sure not to bend the battery too excessively as if bent too much, it could rupture a cell within the battery and possibly cause a fire.
    • The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
Conclusão
5 outras pessoas executaram este guia.
6 comentários
Donde puedo adquirir la batería?
arag12 - Responder
There are no screws on the bottom edge of my invicta model P11A8100. Can I bypass removing screws and proceed to removing the back?
Robert Sandfort - Responder
There are no screws on the bottom of my model P11A8100. Can I bypass removal is said screws and proceed to opening the back?
Great instructions but I cant find a battery replacement. Battery number 3394122-2p
Hank Drabczak - Responder
Great instructions but now I cant find the battery anywhere it is 3394122-2p
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 32
Duração total: 4,623
