Ir para o conteúdo principal
Insignia Flex 10.1 NS-P16AT10 Camera Replacement
O que você precisa
  1. Insignia Flex 10.1 NS-P16AT10 Camera Replacement, Camera: passo 1, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Camera Replacement, Camera: passo 1, imagem 2 %32
    • Make sure your device is off and not connected to any power sources to avoid injury
    • Use a plastic opening tool to remove the rear panel from the front case.
    • Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
    • The volume rocker and power button will become free from the device when the front and rear panels are separated from each other. Do not worry. These pieces are easily put back into place when reassembling the tablet.
  2. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: passo 2, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to flip up the ribbon connector that connects the camera to the motherboard.
    • Free the ribbon cable from the motherboard.
  3. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: passo 3, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: passo 3, imagem 2 %32
    • Use a #00 Phillips head screw driver to remove the two screws that hold the camera down to the front case.
  4. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers or your fingers to remove the camera from your Insignia Flex 10.1 NS-P16AT10.
  5. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: passo 5, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: passo 5, imagem 2 %32
    • The camera is now free and ready to be replaced.
Conclusão
Morgan Kidd
Membro desde: 10/10/16
419 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 12-3, Bennett Fall 2016 Membro de Texas Tech, Team 12-3, Bennett Fall 2016
TTU-BENNETT-F16S12G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 148
