Ir para o conteúdo principal
Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: passo 1, imagem 1 %32
    • Remove the lid and place it upside-down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: passo 2, imagem 1 %32
    • Pinch the rubber gasket on the float valve and pull up.
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: passo 3, imagem 1 %32 Insignia 6-Quart Pressure Cooker Float Valve Replacement: passo 3, imagem 2 %32
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
Conclusão
3 outras pessoas executaram este guia.
Savannah Webb
Membro desde: 01/18/18
657 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S12-G3, Banghart Winter 2018 Membro de Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
Membros da 4
Autoria de 5 guias
2 comentários
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - Responder
OK after much digging, I found the old valve and now it is pressurizing.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 76
Duração total: 4,344
