Introdução
Circuit boards may require replacement after consistent use. This guide will show how to remove the circuit board.
Peças
Não são necessárias peças.
  1. Use a Phillips head #2 screwdriver to remove the 6mm screw.
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Twist the light grey plastic until the holes align with the blockers.
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Remove the power cord from the slot it is inserted in.
    • Remove the power cord from the slot it is inserted in.
  4. Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  7. Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  8. Pinch the small white component connected to the circuit board.
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  9. Pinch the red component connected to the circuit board.
    • Pinch the red component connected to the circuit board.
  10. Wiggle the wide white component until it is removed from the circuit board.
    • Wiggle the wide white component until it is removed from the circuit board.
  11. Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  12. Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  13. Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  14. Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  15. Remove and replace the circuit board.
    • Remove and replace the circuit board.
Conclusão
Savannah Webb
639 reputação
5 Guides authored
Equipe
Cal Poly, Team S12-G3, Banghart Winter 2018 Membro de Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 9
Todo: 134
