Ir para o conteúdo principal
Inline Skates Wheels and Bearings Replacement
O que você precisa
  1. Inline Skates Wheels and Bearings Replacement, Wheels and Bearings: passo 1, imagem 1 %32
    • Locate the axel at the center of the wheel.
  2. Inline Skates Wheels and Bearings Replacement: passo 2, imagem 1 %32 Inline Skates Wheels and Bearings Replacement: passo 2, imagem 2 %32
    • Using an Allen Wrench, place the end of the wrench in the axle in the center of the axle and twist counterclockwise until loose.
  3. Inline Skates Wheels and Bearings Replacement: passo 3, imagem 1 %32 Inline Skates Wheels and Bearings Replacement: passo 3, imagem 2 %32
    • Once the axel is loosened, proceed to slide the wheel along with its axel out of position.
  4. Inline Skates Wheels and Bearings Replacement: passo 4, imagem 1 %32
    • Remove the damaged wheel.
  5. Inline Skates Wheels and Bearings Replacement: passo 5, imagem 1 %32
    • Take this opportunity to clean the frame of the rollerblade.
  6. Inline Skates Wheels and Bearings Replacement: passo 6, imagem 1 %32
    • Gently wedge the Allen Wrench into the bearing and using an upward force at a 35-45 degree angle, carefully slide/pop out the bearing.
    • To reduce the chance of injuring yourself, wedge the bearing away from you
  7. Inline Skates Wheels and Bearings Replacement: passo 7, imagem 1 %32
    • Once the bearing is successfully removed, slide the spacer out.
  8. Inline Skates Wheels and Bearings Replacement: passo 8, imagem 1 %32
    • Then proceed to flip the wheel on its opposite side and use the Allen Wrench again to push out the remaining bearing from the wheel.
  9. Inline Skates Wheels and Bearings Replacement: passo 9, imagem 1 %32
    • Take the new wheel replacement and fit a bearing, place the spacer in the center and place the other bearing on the other side.
  10. Inline Skates Wheels and Bearings Replacement: passo 10, imagem 1 %32 Inline Skates Wheels and Bearings Replacement: passo 10, imagem 2 %32
    • Take the new wheel replacement, and align it with the frame so that the bearings and axle hole align.
    • Proceed to slide the axle through the hole of the frame and bearings and loosely tighten by hand turning clockwise to ensure proper alignment.
  11. Inline Skates Wheels and Bearings Replacement: passo 11, imagem 1 %32 Inline Skates Wheels and Bearings Replacement: passo 11, imagem 2 %32
    • Then proceed to place the end of the wrench in the axle in the center of the wheel and twist clockwise until resistance is felt.
Conclusão
To reassemble your device, follow the instructions in reverse order.
Uma outra pessoa concluiu este guia.
Angelo Barajas
Membro desde: 02/02/24
211 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-8, Andersen Winter 2024 Membro de UC Davis, Team 3-8, Andersen Winter 2024
UCD-ANDERSEN-W24S3G8
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 18
Duração total: 213
