Ir para o conteúdo principal
Infinity v2 10.1 Speakers Replacement
O que você precisa
  1. Infinity v2 10.1 Speakers Replacement, Back Case: passo 1, imagem 1 %32 Infinity v2 10.1 Speakers Replacement, Back Case: passo 1, imagem 2 %32 Infinity v2 10.1 Speakers Replacement, Back Case: passo 1, imagem 3 %32
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Speakers Replacement: passo 2, imagem 1 %32 Infinity v2 10.1 Speakers Replacement: passo 2, imagem 2 %32
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Speakers Replacement, Speakers: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Turn on your soldering iron and allow it to heat up. Once it is hot, press the tip of the iron to the both of the solder points that attach the wires to the motherboard until the solder is melted.
    • Once the solder is melted, use tweezers to remove the wires from the motherboard.
    • The solder and iron will be extremely hot. You can use tweezers to grab the wire to avoid burning your fingers from accidental contact with the iron.
Conclusão
Nate Rice
Membro desde: 10/31/19
321 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 Membro de UMass Dartmouth, Team S2-G4, Barthe Fall 2019
UMASSD-BARTHE-F19S2G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 145
