O que você precisa
In order to get new motor into frame and attach belt you need to put 2 screws in the motor LOOSELY DO NOT TIGHTEN ANYTHING yet .
Now slip on the belt to loose motor and with a good amount of force push to the right until motor belt and motor mount point line up . Now tighten those 2 screws. Motor should be mounted and you can install last 2 bolts.
Quase terminado!
Conclusão
