Ir para o conteúdo principal
Infiniti Q50 Bottom Screen Display Replacement
O que você precisa
  1. Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: passo 1, imagem 1 %32 Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: passo 1, imagem 2 %32 Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: passo 1, imagem 3 %32
    • Use a panel popper or screwdriver to pop out the side panels of the center console.
  2. Infiniti Q50 Bottom Screen Display Replacement: passo 2, imagem 1 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 2, imagem 2 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 2, imagem 3 %32
    • Lift and remove the cup holder piece.
  3. Infiniti Q50 Bottom Screen Display Replacement: passo 3, imagem 1 %32
    • Push down on the gear shift to reveal the clip.
  4. Infiniti Q50 Bottom Screen Display Replacement: passo 4, imagem 1 %32
    • Make sure to engage your emergency brakes and put the car in neutral gear before proceeding with this step.
    • Use a screwdriver to remove the clip from the gear shift.
    • Store this clip in a secure location for safekeeping.
    • Pull off the gear shift knob.
  5. Infiniti Q50 Bottom Screen Display Replacement: passo 5, imagem 1 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 5, imagem 2 %32
    • Remove the two screws found underneath the side panels.
  6. Infiniti Q50 Bottom Screen Display Replacement: passo 6, imagem 1 %32
    • Wiggle to lift the center console over the gear shift.
  7. Infiniti Q50 Bottom Screen Display Replacement: passo 7, imagem 1 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 7, imagem 2 %32
    • Pinch the tip of each connector cord to detach from the center console.
  8. Infiniti Q50 Bottom Screen Display Replacement: passo 8, imagem 1 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 8, imagem 2 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 8, imagem 3 %32
    • Pull off the trim found on either side of the display screen.
  9. Infiniti Q50 Bottom Screen Display Replacement: passo 9, imagem 1 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 9, imagem 2 %32
    • Remove the two screws underneath the trim.
  10. Infiniti Q50 Bottom Screen Display Replacement: passo 10, imagem 1 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 10, imagem 2 %32
    • Wiggle to pull out the bottom screen display.
  11. Infiniti Q50 Bottom Screen Display Replacement: passo 11, imagem 1 %32 Infiniti Q50 Bottom Screen Display Replacement: passo 11, imagem 2 %32
    • Pinch to detach the connector cords.
Conclusão
Roberta Willis
Membro desde: 02/19/24
203 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 46
Ao todo: 462
