Ir para o conteúdo principal
Infant Optics DXR-8 Power Button Replacement
O que você precisa
  1. Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, imagem 1 %32 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, imagem 2 %32 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, imagem 3 %32
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Power Button Replacement: passo 2, imagem 1 %32 Infant Optics DXR-8 Power Button Replacement: passo 2, imagem 2 %32 Infant Optics DXR-8 Power Button Replacement: passo 2, imagem 3 %32
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Power Button Replacement: passo 3, imagem 1 %32 Infant Optics DXR-8 Power Button Replacement: passo 3, imagem 2 %32 Infant Optics DXR-8 Power Button Replacement: passo 3, imagem 3 %32
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Power Button Replacement, Power Button: passo 4, imagem 1 %32
    • The power button is located at the top of the device.
  5. Infant Optics DXR-8 Power Button Replacement: passo 5, imagem 1 %32
    • Remove the button by picking it up out of the hole it is connected to.
  6. Infant Optics DXR-8 Power Button Replacement: passo 6, imagem 1 %32
    • Insert a new button by placing the small end in the hole to connect the button to the device.
Conclusão
To reassemble your device, follow the instructions in reverse order.
3 outras pessoas executaram este guia.
2Comentários do guia
Where did you get the replacement switch?
Dave Peterson - Responder Compartilhar
Where can you purchase a new power switch on the circuit board for replacement?
Derrick Silvestri - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 80
Ao todo: 5,727
