Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the hex head bolt from the top of the access door on the pump head.
Pull the access door straight up off the pump head.
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
Hold the wrench on the bolt stationary.
Loosen the nut.
Pull the top of the chain straight off of the pump handle.
Use a wrench to loosen the nut on the end of the handle axle.
Remove the nut and washer from the end of the axle.
Set the axle punch over the exposed threaded section of the axle.
Gently tap the axle punch to push the axle out of the pump head.
Once the axle is loose, push it through the pump head.
At this point you can inspect the pump handle bearing for damage or excessive wear.
After sliding the pump handle back into the pump head, line up the pump handle bearing with the holes in the side of the pump head.
Insert the axle back into the pump head.
Be sure to support the weight of the handle and line up the holes in the sides of the pump head with the pump handle bearing.
Use a block of wood and hammer to gently tap the axle back into place.
Replace the washer and nut on the axle.
Tighten the nut with a wrench.
