Ir para o conteúdo principal
InFocus Screenplay 4805 Light Tunnel Replacement
O que você precisa
  1. InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: passo 1, imagem 1 %32 InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: passo 1, imagem 2 %32 InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: passo 1, imagem 3 %32
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. InFocus Screenplay 4805 Light Tunnel Replacement: passo 2, imagem 1 %32 InFocus Screenplay 4805 Light Tunnel Replacement: passo 2, imagem 2 %32
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. InFocus Screenplay 4805 Light Tunnel Replacement: passo 3, imagem 1 %32 InFocus Screenplay 4805 Light Tunnel Replacement: passo 3, imagem 2 %32 InFocus Screenplay 4805 Light Tunnel Replacement: passo 3, imagem 3 %32
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  4. InFocus Screenplay 4805 Light Tunnel Replacement: passo 4, imagem 1 %32
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  5. InFocus Screenplay 4805 Light Tunnel Replacement: passo 5, imagem 1 %32
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
  6. InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: passo 6, imagem 1 %32 InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: passo 6, imagem 2 %32 InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: passo 6, imagem 3 %32
    • With the lens facing you, remove the following screws:
    • Using the Phillips #1 screwdriver, remove the (3) three 1.25 cm gold screws holding the metal grate between the color wheel unit and the bulb.
    • Using the Phillips #1 screwdriver, remove the (2) two 2 cm gold screws on the right side of the lens house.
    • Using the Phillips #1 screwdriver and a bent driver, remove the (4) four 2 cm screws on the back of the lens house.
  7. InFocus Screenplay 4805 Light Tunnel Replacement: passo 7, imagem 1 %32 InFocus Screenplay 4805 Light Tunnel Replacement: passo 7, imagem 2 %32 InFocus Screenplay 4805 Light Tunnel Replacement: passo 7, imagem 3 %32
    • Using a Phillips #0 screwdriver remove the three 1 cm black screws from the lens house.
    • Remove the lens unit.
  8. InFocus Screenplay 4805 Light Tunnel Replacement: passo 8, imagem 1 %32 InFocus Screenplay 4805 Light Tunnel Replacement: passo 8, imagem 2 %32 InFocus Screenplay 4805 Light Tunnel Replacement: passo 8, imagem 3 %32
    • Using the Phillips #0 head, unscrew the four 1 cm black screws.
    • Remove the metal casings holding the tunnel in place.
  9. InFocus Screenplay 4805 Light Tunnel Replacement: passo 9, imagem 1 %32 InFocus Screenplay 4805 Light Tunnel Replacement: passo 9, imagem 2 %32
    • Using the Phillips #0 head, unscrew the black 0.5 cm screw on the bottom of the lens house.
    • Remove the light tunnel.
Conclusão
To reassemble the device, follow these instructions in reverse order.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 828
