Ir para o conteúdo principal
InFocus LP540 Projector Main Board Replacement
O que você precisa
  1. InFocus LP540 Projector Main Board Replacement, Main Board: passo 1, imagem 1 %32 InFocus LP540 Projector Main Board Replacement, Main Board: passo 1, imagem 2 %32 InFocus LP540 Projector Main Board Replacement, Main Board: passo 1, imagem 3 %32
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7 mm metallic screws using the flat-head screwdriver.
    • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
  2. InFocus LP540 Projector Main Board Replacement: passo 2, imagem 1 %32 InFocus LP540 Projector Main Board Replacement: passo 2, imagem 2 %32
    • Flip the projector over.
    • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
  3. InFocus LP540 Projector Main Board Replacement: passo 3, imagem 1 %32 InFocus LP540 Projector Main Board Replacement: passo 3, imagem 2 %32 InFocus LP540 Projector Main Board Replacement: passo 3, imagem 3 %32
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Remove the top cover.
  4. InFocus LP540 Projector Main Board Replacement: passo 4, imagem 1 %32 InFocus LP540 Projector Main Board Replacement: passo 4, imagem 2 %32
    • Hold down the release tabs to remove the cables from the white tabs.
  5. InFocus LP540 Projector Main Board Replacement: passo 5, imagem 1 %32 InFocus LP540 Projector Main Board Replacement: passo 5, imagem 2 %32 InFocus LP540 Projector Main Board Replacement: passo 5, imagem 3 %32
    • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
    • Pull up the five metal tabs located at the rear of the projector.
    • Do not pull up on the metal tabs too hard or too fast because they can break easily.
  6. InFocus LP540 Projector Main Board Replacement: passo 6, imagem 1 %32 InFocus LP540 Projector Main Board Replacement: passo 6, imagem 2 %32 InFocus LP540 Projector Main Board Replacement: passo 6, imagem 3 %32
    • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
    • Pull the ribbons out carefully and place them under the main board.
    • Carefully lift the entire main board up.
Conclusão
Uma outra pessoa concluiu este guia.
Jorge L Navarro
Membro desde: 01/22/14
533 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-17, Regan Winter 2014 Membro de Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
Membros da 6
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,120
