O que você precisa
Flip the projector right-side up and turn it so that the back ports are facing you.
Remove the 7 mm metallic screws using the flat-head screwdriver.
Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
Quase terminado!
Conclusão
