O que você precisa
Carefully remove the rubber fan bumper from the edge of the heat sink.
Ferramenta utilizada neste passo:Tweezers$4.99
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
One of the screws holding the top shell of the fan assembly is hidden just behind the I/O board cable.
Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
Remove the I/O board cable bracket.
3 outras pessoas executaram este guia.
