Ir para o conteúdo principal
Impuls Blender Electronic wire Replacement
O que você precisa
  1. Impuls Blender Electronic wire Replacement, Electronic wire: passo 1, imagem 1 %32 Impuls Blender Electronic wire Replacement, Electronic wire: passo 1, imagem 2 %32 Impuls Blender Electronic wire Replacement, Electronic wire: passo 1, imagem 3 %32
    • Here you see the Impuls blender
    • First, seperate the the blender jar from the bottom part by turning it and put it aside.
  2. Impuls Blender Electronic wire Replacement: passo 2, imagem 1 %32 Impuls Blender Electronic wire Replacement: passo 2, imagem 2 %32 Impuls Blender Electronic wire Replacement: passo 2, imagem 3 %32
    • Turn the bottom part over and look at the bottom.
    • Take the rubber parts out of the 4 holes to reveal the screws.
    • Take the 4 screws out using a Phillips screwdriver.
  3. Impuls Blender Electronic wire Replacement: passo 3, imagem 1 %32 Impuls Blender Electronic wire Replacement: passo 3, imagem 2 %32 Impuls Blender Electronic wire Replacement: passo 3, imagem 3 %32
    • Take the blue bottom part off the rest of the product to reveal the inside.
    • Unscrew the black piece to be able to slide the blue part away from the rest.
  4. Impuls Blender Electronic wire Replacement: passo 4, imagem 1 %32 Impuls Blender Electronic wire Replacement: passo 4, imagem 2 %32 Impuls Blender Electronic wire Replacement: passo 4, imagem 3 %32
    • When you look to the inside, you see that there are two components; the buttons and the motor.
    • Unscrew the part that contains the buttons and take it off.
  5. Impuls Blender Electronic wire Replacement: passo 5, imagem 1 %32 Impuls Blender Electronic wire Replacement: passo 5, imagem 2 %32 Impuls Blender Electronic wire Replacement: passo 5, imagem 3 %32
    • Take out the 3 screws that are deep inside.
    • Take off the blue part on top that was fixed with those screws.
    • Pull the black disc out by using the screwdriver as lever from multiple sides.
    • This will take some force, so do not be afraid it will break.
  6. Impuls Blender Electronic wire Replacement: passo 6, imagem 1 %32 Impuls Blender Electronic wire Replacement: passo 6, imagem 2 %32 Impuls Blender Electronic wire Replacement: passo 6, imagem 3 %32
    • When you have taken off the black piece and revealed the 4 screws, unscrew them all.
    • Take out the motor part and the rest of the electronics.
  7. Impuls Blender Electronic wire Replacement: passo 7, imagem 1 %32 Impuls Blender Electronic wire Replacement: passo 7, imagem 2 %32 Impuls Blender Electronic wire Replacement: passo 7, imagem 3 %32
    • Find the fraction in the wire.
    • Cut off the broken part
    • Strip both sides of the wire that have to be attached again.
  8. Impuls Blender Electronic wire Replacement: passo 8, imagem 1 %32 Impuls Blender Electronic wire Replacement: passo 8, imagem 2 %32
    • If you will use a shrink sleeve to cover the electronic wire, it has to be put on the wire first. Otherwise if electrical tape is used, this can be done afterwards.
    • Solder the two wires with a soldering iron.
    • Shrink the sleeve with a heater or put the electrical tape around the soldered wire.
Conclusão
To reassemble your device, follow the instructions in reverse order.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Duração total: 1,020
