Ir para o conteúdo principal
Impressions Vanity Mirror Light Bulb Replacement
O que você precisa
  1. Impressions Vanity Mirror Light Bulb Replacement, Light Bulb: passo 1, imagem 1 %32 Impressions Vanity Mirror Light Bulb Replacement, Light Bulb: passo 1, imagem 2 %32 Impressions Vanity Mirror Light Bulb Replacement, Light Bulb: passo 1, imagem 3 %32
    • Turn on your mirror to see which light bulb is not working.
  2. Impressions Vanity Mirror Light Bulb Replacement: passo 2, imagem 1 %32 Impressions Vanity Mirror Light Bulb Replacement: passo 2, imagem 2 %32 Impressions Vanity Mirror Light Bulb Replacement: passo 2, imagem 3 %32
    • Now that you know which bulb isn't working, turn off the mirror and disconnect it from the wall outlet to avoid any injuries.
  3. Impressions Vanity Mirror Light Bulb Replacement: passo 3, imagem 1 %32 Impressions Vanity Mirror Light Bulb Replacement: passo 3, imagem 2 %32
    • Turn the light bulb counter clockwise to remove it from the mirror.
  4. Impressions Vanity Mirror Light Bulb Replacement: passo 4, imagem 1 %32
    • Make sure the light bulb that you bought is the same model and wattage as the one you removed.
  5. Impressions Vanity Mirror Light Bulb Replacement: passo 5, imagem 1 %32 Impressions Vanity Mirror Light Bulb Replacement: passo 5, imagem 2 %32
    • Place the new light bulb in its socket and turn it clockwise to secure it.
  6. Impressions Vanity Mirror Light Bulb Replacement: passo 6, imagem 1 %32 Impressions Vanity Mirror Light Bulb Replacement: passo 6, imagem 2 %32
    • Make sure that the bulb is secured in place.
    • If it's not well-secured, the bulb won't light up when the mirror is turned on.
  7. Impressions Vanity Mirror Light Bulb Replacement: passo 7, imagem 1 %32
    • Plug the mirror back into the outlet.
  8. Impressions Vanity Mirror Light Bulb Replacement: passo 8, imagem 1 %32 Impressions Vanity Mirror Light Bulb Replacement: passo 8, imagem 2 %32 Impressions Vanity Mirror Light Bulb Replacement: passo 8, imagem 3 %32
    • Turn on the mirror and check that the new bulb works.
Linha de Chegada
Yasmin Olivera
Membro desde: 04/17/21
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 46
Duração total: 587
