Ir para o conteúdo principal
Impression i7 Front Camera Replacement
O que você precisa
  1. Impression i7 Front Camera Replacement, Battery: passo 1, imagem 1 %32
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 Front Camera Replacement: passo 2, imagem 1 %32
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 Front Camera Replacement: passo 3, imagem 1 %32
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 Front Camera Replacement: passo 4, imagem 1 %32 Impression i7 Front Camera Replacement: passo 4, imagem 2 %32
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 Front Camera Replacement: passo 5, imagem 1 %32
    • Desolder the positive and negative leads.
  6. Impression i7 Front Camera Replacement: passo 6, imagem 1 %32 Impression i7 Front Camera Replacement: passo 6, imagem 2 %32
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  7. Impression i7 Front Camera Replacement, Front Camera: passo 7, imagem 1 %32
    • Gently pull the front camera connection out of its socket.
  8. Impression i7 Front Camera Replacement: passo 8, imagem 1 %32
    • Lift the camera unit from its housing. The unit should come out with minimal force.
Conclusão
Cole Beaver
Membro desde: 11/05/18
390 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G5, Baechle Fall 2018 Membro de IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 99
