Ir para o conteúdo principal
Imation Superdisk USB Drive Plastic Housing Replacement
O que você precisa
  1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: passo 1, imagem 1 %32 Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: passo 1, imagem 2 %32
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Plastic Housing Replacement: passo 2, imagem 1 %32 Imation Superdisk USB Drive Plastic Housing Replacement: passo 2, imagem 2 %32
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Plastic Housing Replacement: passo 3, imagem 1 %32 Imation Superdisk USB Drive Plastic Housing Replacement: passo 3, imagem 2 %32
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Plastic Housing Replacement: passo 4, imagem 1 %32 Imation Superdisk USB Drive Plastic Housing Replacement: passo 4, imagem 2 %32
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Plastic Housing Replacement: passo 5, imagem 1 %32 Imation Superdisk USB Drive Plastic Housing Replacement: passo 5, imagem 2 %32
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Plastic Housing Replacement: passo 6, imagem 1 %32 Imation Superdisk USB Drive Plastic Housing Replacement: passo 6, imagem 2 %32
    • Slide the metal housing out of the plastic shell.
Conclusão
Uma outra pessoa concluiu este guia.
Caitlin Horwatt
Membro desde: 02/11/14
137 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 1-2, Buehl Spring 2014 Membro de Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 805
