Ir para o conteúdo principal
Imation Superdisk USB Drive Daughter Board Replacement
O que você precisa
  1. Imation Superdisk USB Drive Daughter Board Replacement, Plastic Housing: passo 1, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement, Plastic Housing: passo 1, imagem 2 %32
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Daughter Board Replacement: passo 2, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement: passo 2, imagem 2 %32
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Daughter Board Replacement: passo 3, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement: passo 3, imagem 2 %32
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Daughter Board Replacement: passo 4, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement: passo 4, imagem 2 %32
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Daughter Board Replacement: passo 5, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement: passo 5, imagem 2 %32
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Daughter Board Replacement: passo 6, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement: passo 6, imagem 2 %32
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Daughter Board Replacement, Metal Casing: passo 7, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement, Metal Casing: passo 7, imagem 2 %32
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Daughter Board Replacement: passo 8, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement: passo 8, imagem 2 %32
    • Slide disk drive out of metal casing.
  9. Imation Superdisk USB Drive Daughter Board Replacement, Daughter Board: passo 9, imagem 1 %32
    • Flip the disk drive over so the the plug on the daughter board is visible.
  10. Imation Superdisk USB Drive Daughter Board Replacement: passo 10, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement: passo 10, imagem 2 %32
    • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
  11. Imation Superdisk USB Drive Daughter Board Replacement: passo 11, imagem 1 %32 Imation Superdisk USB Drive Daughter Board Replacement: passo 11, imagem 2 %32
    • Gently pull on the daughter board until it separates from the device.
Conclusão
Darlena
Membro desde: 02/11/14
219 Reputação
Autoria de 3 guias
Equipe
Ohio State, Team 1-2, Buehl Spring 2014 Membro de Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 992
