Ir para o conteúdo principal
Ikea RESGODS Bed Tray Leg Replacement
O que você precisa
  1. Ikea RESGODS Bed Tray Leg Replacement, Ikea RESGODS Bed Tray Leg Replacement: passo 1, imagem 1 %32 Ikea RESGODS Bed Tray Leg Replacement, Ikea RESGODS Bed Tray Leg Replacement: passo 1, imagem 2 %32
    • Carefully place the bed tray face down on an even surface.
    • Avoid working on a table or surface that you wouldn't want to get scratched. While the repair is safe, you could inadvertently scratch the tabletop.
  2. Ikea RESGODS Bed Tray Leg Replacement: passo 2, imagem 1 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 2, imagem 2 %32
    • Identify which screw is loose or which leg is detached.
    • Lift the bed tray leg by two millimeters.
  3. Ikea RESGODS Bed Tray Leg Replacement: passo 3, imagem 1 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 3, imagem 2 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 3, imagem 3 %32
    • Insert the 1/2 inch truss head screw inside the leg hole.
  4. Ikea RESGODS Bed Tray Leg Replacement: passo 4, imagem 1 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 4, imagem 2 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 4, imagem 3 %32
    • Slide two steel flat washers onto the screw.
  5. Ikea RESGODS Bed Tray Leg Replacement: passo 5, imagem 1 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 5, imagem 2 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 5, imagem 3 %32
    • Attach the leg to the hole with the screw and steel flat washers.
  6. Ikea RESGODS Bed Tray Leg Replacement: passo 6, imagem 1 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 6, imagem 2 %32 Ikea RESGODS Bed Tray Leg Replacement: passo 6, imagem 3 %32
    • Use a Phillips #00 screwdriver to secure the screw to the tray.
Conclusão
In conclusion, this guide is generally easy. You will just need the right screws and steel flat washer to fix it.
Uma outra pessoa concluiu este guia.
Erik Francisco
Membro desde: 01/12/24
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 407
