Ir para o conteúdo principal
Igloo Mini Fridge IRF32BK Compressor Relay Replacement
O que você precisa
  1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: passo 1, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: passo 1, imagem 2 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: passo 1, imagem 3 %32
    • Clear out all food products in the refrigerator.
    • Unplug the plug from the outlet.
    • Turn the refrigerator backward.
    • Don't turn the mini fridge on its side. Doing so will ruin the mini fridge gas.
  2. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 2, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 2, imagem 2 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 2, imagem 3 %32
    • Use a knife to cut the plastic holding strips.
    • Don't damage the rubber covering. Damaging it can be dangerous when turning the mini fridge back on.
  3. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 3, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 3, imagem 2 %32
    • Use your thumbs to open the rubber covering.
  4. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 4, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 4, imagem 2 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 4, imagem 3 %32
    • Use the CR-V screwdriver to unscrew the screw by rotating the screwdriver counter clockwise.
  5. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 5, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 5, imagem 2 %32
    • Push the flathead screwdriver upward to pry open the metal hinge.
    • Repeat this same step on the other side.
  6. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 6, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 6, imagem 2 %32
    • Remove the plastic box by pulling it away from the wires.
  7. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 7, imagem 1 %32
    • Stick the flathead screwdriver in between the compressor relay and the pot.
    • Wiggle the screwdriver left to right five times.
    • Use your hand to pull the compressor relay from the pot.
  8. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 8, imagem 1 %32
    • Use the flathead screwdriver to push the white cable against the compressor relay to disconnect it.
  9. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 9, imagem 1 %32
    • Connect the white cable to the new compressor relay.
    • You should hear a click when you connect it correctly.
  10. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 10, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 10, imagem 2 %32
    • Connect the holes on the compressor relay to the pot.
    • Connect the top hole on the white part of the compressor relay first, then connect the rest of the holes.
  11. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 11, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 11, imagem 2 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 11, imagem 3 %32
    • Hold the plastic box as shown in the picture and put it on the compressor relay.
    • Reattach the metal hinge back onto the plastic box.
    • You should hear a click when putting back on the metal hinge.
    • These two steps must be done at the same time in order to work.
  12. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 12, imagem 1 %32
    • Reattach the screw to the green wire and use the CR-V screwdriver to reinsert the screw.
    • Refer back to Step 4 to help you complete this step.
  13. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 13, imagem 1 %32 Igloo Mini Fridge IRF32BK Compressor Relay Replacement: passo 13, imagem 2 %32
    • Warp the rubber coating back onto the metal wire.
    • Warp the new plastic holding stripes onto the rubber coating.
Linha de Chegada
14 outras pessoas executaram este guia.
Rizwan Laghari
Membro desde: 09/30/21
217 Reputação
Autoria de 1 guia
6Comentários do guia
Would you happen to know the part numbers for the start relay and overload on this mini fridge that you are working on in this tutorial?
chrisalexandre - Responder
Hi, I have a question?? Does the Igloo irf32bk have a "linear compressor" ?
bruce o - Responder
re-try post! ok,here goes.....does the Igloo IRF32BK operate with a "linear" compressor?
bruce o - Responder
X q no enfria el refrigerador y si prende el motor y tiene gas
Angel antonio Coronado uribe - Responder
Relay connection ke bare mein sabhi star jankari sajha kijiye aur kaun si cable kahan per lagani chahie
Gulabsing Girase - Responder
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 103
Últimos 30 dias: 498
Ao todo: 18,189
