Ir para o conteúdo principal
Identifying Delphi MyFi XM2GO Device Number
  1. Identifying Delphi MyFi XM2GO Device Number, Battery Cover: passo 1, imagem 1 %32 Identifying Delphi MyFi XM2GO Device Number, Battery Cover: passo 1, imagem 2 %32 Identifying Delphi MyFi XM2GO Device Number, Battery Cover: passo 1, imagem 3 %32
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Identifying Delphi MyFi XM2GO Device Number, Battery: passo 2, imagem 1 %32 Identifying Delphi MyFi XM2GO Device Number, Battery: passo 2, imagem 2 %32 Identifying Delphi MyFi XM2GO Device Number, Battery: passo 2, imagem 3 %32
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. Identifying Delphi MyFi XM2GO Device Number, Identifying Delphi MyFi XM2GO Device Number: passo 3, imagem 1 %32
    • After removing the battery cover and battery, the device information is located near the battery connections highlighted in red.
Conclusão
Scott Byer
Membro desde: 03/09/12
88 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 1-2, Benson Spring 2012 Membro de Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Membros
Autoria de 9 guias
1Comentário do guia
What is that pad behind battery ?is ot a thermal pad of some kind?
Torey Mitchell - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 53
Ao todo: 1,699
