Ir para o conteúdo principal
Ideapad 3-17IAU7 Solid State Drive Replacement
O que você precisa
  1. Ideapad 3-17IAU7 Solid State Drive Replacement, Removing Bottom Case: passo 1, imagem 1 %32
    • Please turn off the device before opening the device
    • Remove the ten screws as shown in picture
    • The four bottom screws are different length for the other screws! (Blue Circle)
    • Remove the bottom case using a guitar pick
  2. Ideapad 3-17IAU7 Solid State Drive Replacement, Removing SSD: passo 2, imagem 1 %32
    • Using the screw driver remove the screw (Red Circle)
    • The device will be lifted remove it by pulling the device.
  3. Ideapad 3-17IAU7 Solid State Drive Replacement, Adding new SSD: passo 3, imagem 1 %32
    • Insert the new SSD according the pins on the motherboard.
    • Push gently on the SSD and screw it using the screw which was removed
Conclusão
Ilia Tocheny
Membro desde: 04/30/19
1.640 Reputação
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 201
