Ir para o conteúdo principal
Ibanez Overdrive Battery Replacement
O que você precisa
  1. Ibanez Overdrive Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before replacing the battery, ensure the stompbox is turned off and disconnected from the power supply.
    • The red LED top of the potentiometer means the stompbox is on. No light from LED means the stompbox is off.
  2. Ibanez Overdrive Battery Replacement: passo 2, imagem 1 %32 Ibanez Overdrive Battery Replacement: passo 2, imagem 2 %32 Ibanez Overdrive Battery Replacement: passo 2, imagem 3 %32
    • Verify the stompbox is off, before doing any repairs.
    • Rotate the stompbox onto its back. There will be four screws. Using a 1/4 Phillip screwdriver, remove all four screws from the back plate.
    • Remove all four screws by turning them counterclockwise.
  3. Ibanez Overdrive Battery Replacement: passo 3, imagem 1 %32 Ibanez Overdrive Battery Replacement: passo 3, imagem 2 %32 Ibanez Overdrive Battery Replacement: passo 3, imagem 3 %32
    • Remove the back plate of the stompbox by lifting the backplate upwards.
    • Next, locate the 9-volt battery, which should be at the bottom of the overdrive stompbox, and carefully pull apart the battery from the battery clip connector.
  4. Ibanez Overdrive Battery Replacement: passo 4, imagem 1 %32 Ibanez Overdrive Battery Replacement: passo 4, imagem 2 %32 Ibanez Overdrive Battery Replacement: passo 4, imagem 3 %32
    • After removing the depleted battery, insert a new 9-volt battery. Ensure the battery and battery clip connector are connected as shown in the photo.
    • After connecting the battery and battery clip connector, carefully reposition both items to their original position, as shown in the photo.
  5. Ibanez Overdrive Battery Replacement: passo 5, imagem 1 %32 Ibanez Overdrive Battery Replacement: passo 5, imagem 2 %32 Ibanez Overdrive Battery Replacement: passo 5, imagem 3 %32
    • Once the battery is positioned at its original position, reattach the back plate.
    • Using a 1/4 Phillip screwdriver, re-screw all four screws onto the back plate.
    • Reattach all four screws by turning them clockwise.
Linha de Chegada
Juan Colon
Membro desde: 03/20/24
121 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 1-1, Harris Spring 2024 Membro de CSU Los Angeles, Team 1-1, Harris Spring 2024
CSULA-HARRIS-S24S1G1
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 104
