Ir para o conteúdo principal
Ibanez Bass Guitar String Replacement
O que você precisa
  1. Ibanez Bass Guitar String Replacement, String: passo 1, imagem 1 %32 Ibanez Bass Guitar String Replacement, String: passo 1, imagem 2 %32
    • In this picture you will find the headstock of the bass.
    • Turning the tuning peg counter clockwise to loosen the string.
    • Here you may use a drill as an easy and fast alternative.
  2. Ibanez Bass Guitar String Replacement: passo 2, imagem 1 %32 Ibanez Bass Guitar String Replacement: passo 2, imagem 2 %32
    • Pull the string from the bottom of the bass from the guitar's bridge.
  3. Ibanez Bass Guitar String Replacement: passo 3, imagem 1 %32 Ibanez Bass Guitar String Replacement: passo 3, imagem 2 %32
    • Pull the string through the guitar's bridge and upward though the headstock of the guitar.
  4. Ibanez Bass Guitar String Replacement: passo 4, imagem 1 %32 Ibanez Bass Guitar String Replacement: passo 4, imagem 2 %32
    • Wrap the new string around the corresponding tuning peg.
  5. Ibanez Bass Guitar String Replacement: passo 5, imagem 1 %32 Ibanez Bass Guitar String Replacement: passo 5, imagem 2 %32
    • Tighten the string by turning the tuning peg.
  6. Ibanez Bass Guitar String Replacement: passo 6, imagem 1 %32 Ibanez Bass Guitar String Replacement: passo 6, imagem 2 %32
    • Repeat steps 2 through 5 until you have changed all four strings.
Conclusão
After you remove the first string, you will reassemble and continue the process until you have changed all four strings.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 47
Duração total: 554
