Ir para o conteúdo principal
Ibanez 5 String Bass Model SR405QM Intonation Adjustment
O que você precisa
  1. Ibanez 5 String Bass Model SR405QM Intonation Adjustment, Strings: passo 1, imagem 1 %32
    • Loosen all of the strings completely by turning each tuning peg counter clockwise. Continue until there is no tension in the strings
  2. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 2, imagem 1 %32
    • Remove each string by pulling it out of the string tree at the top and through the bridge at the bottom.
  3. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 3, imagem 1 %32
    • Thread the largest new string through the bridge hole farthest from the knobs. Hold it firmly in place.
  4. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 4, imagem 1 %32
    • Pull the string up to the corresponding string tree.
  5. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 5, imagem 1 %32
    • Firmly grasp the middle of the string and pull it taut.
  6. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 6, imagem 1 %32 Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 6, imagem 2 %32
    • On a taut string, measure one inch past the nut before using a pair of wire cutters to cut the string.
  7. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 7, imagem 1 %32
    • Take the end of the string and insert it into the hole in the middle of the string tree.
  8. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 8, imagem 1 %32
    • Bend the string sideways into the channel of the string tree.
  9. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 9, imagem 1 %32
    • Use one hand to maintain tension in the string by grabbing the string and rotating the hand toward the fret board.
    • If tension is not retained it may result in uneven tension in the string tree, causing the tree to break.
  10. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 10, imagem 1 %32
    • Rotate the tuning peg counterclockwise until the string is slightly taut, but not tight.
    • Check to ensure that the string is lined up with the proper notch in the nut.
    • You will have proper alignment when the sting bends at a minimum angle.
  11. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 11, imagem 1 %32
    • Repeat steps 3-10 for each string.
    • Each string will progressively get closer to the knobs. It is not essential to progress from thick to thin strings, but it is important that they are connected to the proper string tree.
  12. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 12, imagem 1 %32
    • Caution: Do not over tighten the strings. This can cause the strings to snap and could cause bodily injury. The strings are too tight when you have difficulty turning the tuning peg.
    • Tighten the string until it is close to the proper tuning. Use an electronic tuner or an online tuner that uses your computer's microphone. (Google: Online Tuner)
    • Note: Clockwise rotation of the tuning peg tightens the string and produces a higher pitch. Counter-clockwise rotation loosens the string causing a lower pitch.
    • Tune the thickest string to B, the second thickest string E, the next thickest to A, the next string to D, and the last string to G.
  13. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 13, imagem 1 %32
    • Because the strings will change pitch as the guitar body deforms due to increased tension, repeat step 12 after each string is tuned individually.
  14. Ibanez 5 String Bass Model SR405QM Intonation Adjustment, Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 14, imagem 1 %32 Ibanez 5 String Bass Model SR405QM Intonation Adjustment, Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 14, imagem 2 %32
    • Plug the instrument cable into input jack.
    • Plug the other end of cable into the tuner.
  15. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 15, imagem 1 %32
    • Tune strings following string replacement guide.
  16. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 16, imagem 1 %32 Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 16, imagem 2 %32
    • Check the intonation of each of your strings by playing the 12th fret and 24th fret.
    • In the pictures, we can see that on the G string the 12th is slightly flat (as the red light to the left of the green light is illuminated) and the 24th fret is slightly sharp (as the red light to the right of the green light is illuminated)
  17. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 17, imagem 1 %32 Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 17, imagem 2 %32
    • After determining which string you need to intonate, locate the corresponding bridge.
    • Note: In our demo we will change the intonation of the G string.
    • Locate the corresponding Phillips head screw we will use to change the position of the bridge.
  18. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 18, imagem 1 %32
    • Our G string was slightly sharp at high notes, therefore we will unscrew the screw in order to make the string longer.
    • If the string is sharp at high notes, loosen the screw, making the string longer.If the string is flat at high notes, tighten the screw, making the string shorter.
  19. Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 19, imagem 1 %32 Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 19, imagem 2 %32 Ibanez 5 String Bass Model SR405QM Intonation Adjustment: passo 19, imagem 3 %32
    • Re-tune the string, and then recheck the pitch of the 12th and 24th fret. Note how only the green light is illuminated, indicating that the pitch is now a G.
    • If the 12th and 24th fret are not in tune, repeat step 5 until they are in tune.
    • If the 12th and 24th fret are in tune, repeat steps 3 through 5 for each of your strings until each string is intonated.
Linha de Chegada
Chris Pittner
Membro desde: 01/11/13
220 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 5-18, Forte Winter 2013 Membro de Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 3,056
