Ir para o conteúdo principal
ION Electric Ice Auger Safety Paddle Replacement
O que você precisa
  1. ION Electric Ice Auger Safety Paddle Replacement, ION Electric Ice Auger Safety Paddle: passo 1, imagem 1 %32
    • Before starting this repair, ensure that the battery has been removed from the power head.
    • Removing the power head from the the auger makes manipulating the unit easier.
  2. ION Electric Ice Auger Safety Paddle Replacement: passo 2, imagem 1 %32
    • On the inside of the trigger side grip, locate the 3 T10 torque screws recessed into the grip.
  3. ION Electric Ice Auger Safety Paddle Replacement: passo 3, imagem 1 %32
    • With a T10 torque screw driver, remove the 3 screws.
  4. ION Electric Ice Auger Safety Paddle Replacement: passo 4, imagem 1 %32
    • Remove the outside half of the trigger side grip.
  5. ION Electric Ice Auger Safety Paddle Replacement: passo 5, imagem 1 %32
    • With a pair of needle nosed pliers, remove the safety paddle return spring.
  6. ION Electric Ice Auger Safety Paddle Replacement: passo 6, imagem 1 %32
    • Remove the broken safety paddle with your fingers.
Conclusão
Uma outra pessoa concluiu este guia.
Grant Larson
Membro desde: 04/26/16
125 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 4,037
