Ir para o conteúdo principal
IBM Thinkpad T61 Trackpad Replacement
O que você precisa
  1. IBM Thinkpad T61 Trackpad Replacement, Trackpad: passo 1, imagem 1 %32
    • Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
  2. IBM Thinkpad T61 Trackpad Replacement: passo 2, imagem 1 %32
    • With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
  3. IBM Thinkpad T61 Trackpad Replacement: passo 3, imagem 1 %32 IBM Thinkpad T61 Trackpad Replacement: passo 3, imagem 2 %32
    • Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
    • Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
  4. IBM Thinkpad T61 Trackpad Replacement: passo 4, imagem 1 %32 IBM Thinkpad T61 Trackpad Replacement: passo 4, imagem 2 %32 IBM Thinkpad T61 Trackpad Replacement: passo 4, imagem 3 %32
    • Separate the trackpad with the bottom mouse buttons from the trackpad panel.
  5. IBM Thinkpad T61 Trackpad Replacement: passo 5, imagem 1 %32
    • Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
  6. IBM Thinkpad T61 Trackpad Replacement: passo 6, imagem 1 %32
    • Reinsert the white plug.
  7. IBM Thinkpad T61 Trackpad Replacement: passo 7, imagem 1 %32 IBM Thinkpad T61 Trackpad Replacement: passo 7, imagem 2 %32
    • Replace the trackpad panel.
    • Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
Conclusão
Replace the battery and plug in your computer. Test out your new trackpad!
6 outras pessoas executaram este guia.
Raymond Lawton
Membro desde: 03/12/14
245 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014 Membro de UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G6
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,769
