Ir para o conteúdo principal
IBM/Lenovo Thinkpad T61 Hard Drive Replacement
O que você precisa
  1. IBM/Lenovo Thinkpad T61 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: passo 2, imagem 1 %32
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: passo 3, imagem 1 %32
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  4. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: passo 4, imagem 1 %32 IBM/Lenovo Thinkpad T61 Hard Drive Replacement: passo 4, imagem 2 %32
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  5. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: passo 5, imagem 1 %32 IBM/Lenovo Thinkpad T61 Hard Drive Replacement: passo 5, imagem 2 %32
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  6. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
Conclusão
To reassemble your device, follow these instructions in reverse order. If your pull tab is broken, you will need to find something to use as a pull tab for the new drive. You can get a long piece of tape, and fold the end and stick the rest to the drive.
7 outras pessoas executaram este guia.
Kyle
Membro desde: 04/18/13
458 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 8-58, Johann Spring 2013 Membro de Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
Membros da 4
Autoria de 10 guias
Um comentário
Ibm t61 caddy rail purchase
Afjal Ansari - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 62
Duração total: 6,563
