Ir para o conteúdo principal
IBM ThinkPad X41 Keyboard Replacement
O que você precisa
  1. IBM ThinkPad X41 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 IBM ThinkPad X41 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 IBM ThinkPad X41 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Slide outward to unlock and lift battery up to remove.
    • Remove battery before keyboard to avoid damage to battery.
  2. IBM ThinkPad X41 Keyboard Replacement: passo 2, imagem 1 %32
    • With a Phillips PH000 to remove all six 6 mm screws identified for the keyboard as shown.
  3. IBM ThinkPad X41 Keyboard Replacement: passo 3, imagem 1 %32 IBM ThinkPad X41 Keyboard Replacement: passo 3, imagem 2 %32 IBM ThinkPad X41 Keyboard Replacement: passo 3, imagem 3 %32
    • Flip the laptop over once more returning it to its upright position and open laptop .
  4. IBM ThinkPad X41 Keyboard Replacement: passo 4, imagem 1 %32 IBM ThinkPad X41 Keyboard Replacement: passo 4, imagem 2 %32
    • Using your left hand, place thumb on the upper part of the keyboard and place your other thumb on the bottom part of the keyboard.
    • Push firmly upward with both thumbs. This will detach keyboard from base.
    • Be cautious when lifting as there is an orange connection cable still attached to the bottom side.
  5. IBM ThinkPad X41 Keyboard Replacement: passo 5, imagem 1 %32 IBM ThinkPad X41 Keyboard Replacement: passo 5, imagem 2 %32
    • Detach the connection to the motherboard by first sliding it towards you, then pulling upward away from your body.
    • This step's directions are based on the angle shown .
  6. IBM ThinkPad X41 Keyboard Replacement: passo 6, imagem 1 %32
    • Lift the entire keyboard off the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Lisbeth Cisneros
Membro desde: 09/12/16
131 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2016
CSUF-BRUCE-F16S2G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 746
