Ir para o conteúdo principal
IBM ThinkPad T43 CD Drive Replacement
O que você precisa
  1. IBM ThinkPad T43 CD Drive Replacement, CD Drive: passo 1, imagem 1 %32
    • Start by having the right side of the laptop facing you.
    • The laptop can be open if you would like, but it can be done easier if it is closed.
  2. IBM ThinkPad T43 CD Drive Replacement: passo 2, imagem 1 %32
    • Remove the screw to be able to use the CD drive unlock switch
  3. IBM ThinkPad T43 CD Drive Replacement: passo 3, imagem 1 %32
    • Locate the switch on the right side of the CD Drive.
  4. IBM ThinkPad T43 CD Drive Replacement: passo 4, imagem 1 %32 IBM ThinkPad T43 CD Drive Replacement: passo 4, imagem 2 %32 IBM ThinkPad T43 CD Drive Replacement: passo 4, imagem 3 %32
    • Place finger in between the switch and the bumper
    • Slide the switch to the right until the plastic tab ejects.
  5. IBM ThinkPad T43 CD Drive Replacement: passo 5, imagem 1 %32 IBM ThinkPad T43 CD Drive Replacement: passo 5, imagem 2 %32 IBM ThinkPad T43 CD Drive Replacement: passo 5, imagem 3 %32
    • Place fingers on the plastic tab.
    • Pull on the tab until the CD Drive ejects.
    • The tab only comes out about an inch to inch and a half.
    • Do not try to pull the tab all the way out.
    • If after you have removed the CD Drive and the tab goes back in, it is alright. It does not affect the later process.
  6. IBM ThinkPad T43 CD Drive Replacement: passo 6, imagem 1 %32 IBM ThinkPad T43 CD Drive Replacement: passo 6, imagem 2 %32
    • Grab the end of the CD Drive and pulls straight out towards your body.
    • Be careful not to pull it out at an angle to not risk damage.
  7. IBM ThinkPad T43 CD Drive Replacement: passo 7, imagem 1 %32
    • Now that you have successfully removed the CD Drive you can put in the new one.
    • Place the end of the new CD Drive in and slide in until it clicks.
    • If you are using slight force and it doesn't go in, it could be jammed. Just take it out and try again.
    • If you had not already, you can push back in the tab.
Conclusão
Uma outra pessoa concluiu este guia.
aLiX pIeRRe
Membro desde: 03/19/18
855 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 Membro de UMass Dartmouth, Team S6-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S6G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 840
