Ir para o conteúdo principal
IBM ThinkPad T42 Wi-Fi Card Replacement
O que você precisa
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: passo 1, imagem 1 %32
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: passo 2, imagem 1 %32
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - Responder
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - Responder
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: passo 3, imagem 1 %32
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: passo 4, imagem 1 %32 IBM ThinkPad T42 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: passo 5, imagem 1 %32
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: passo 6, imagem 1 %32
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: passo 7, imagem 1 %32
    • Carefully pull it out.
Conclusão
3 outras pessoas executaram este guia.
Kevin Rehm
Membro desde: 04/19/10
472 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 29-76, Johann Spring 2010 Membro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
Membros da 4
Autoria de 35 guias
Um comentário
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Duração total: 13,734
