Ir para o conteúdo principal
IBM ThinkPad T42 Speakers Replacement
O que você precisa
  1. IBM ThinkPad T42 Speakers Replacement, Bottom cover: passo 1, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Speakers Replacement, Rear screws: passo 2, imagem 1 %32
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Speakers Replacement, Keyboard and Trackpad: passo 3, imagem 1 %32
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Speakers Replacement: passo 4, imagem 1 %32 IBM ThinkPad T42 Speakers Replacement: passo 4, imagem 2 %32
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Speakers Replacement, Lower Bracket: passo 5, imagem 1 %32 IBM ThinkPad T42 Speakers Replacement, Lower Bracket: passo 5, imagem 2 %32
    • Grasp the metal bracket to remove it from the device.
  6. IBM ThinkPad T42 Speakers Replacement, Microphone cover: passo 6, imagem 1 %32
    • Remove the rubber cover from the microphone.
  7. IBM ThinkPad T42 Speakers Replacement, Speakers: passo 7, imagem 1 %32 IBM ThinkPad T42 Speakers Replacement, Speakers: passo 7, imagem 2 %32
    • Check to ensure the speaker cartridge moves freely before removing the cartridge.
    • Disconnect the speaker wire from the unit and carefully remove the speaker.
Conclusão
Gerald Watanabe
Membro desde: 04/14/10
288 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 29-76, Johann Spring 2010 Membro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
Membros da 4
Autoria de 37 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 5,379
