Ir para o conteúdo principal
IBM ThinkPad T42 RAM Replacement
O que você precisa
  1. IBM ThinkPad T42 RAM Replacement, Battery Clips: passo 1, imagem 1 %32
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 RAM Replacement, Removing the Battery: passo 2, imagem 1 %32
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 RAM Replacement, RAM: passo 3, imagem 1 %32
    • Unscrew the pictured screwed holding the memory cover in place.
  4. IBM ThinkPad T42 RAM Replacement: passo 4, imagem 1 %32
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
    • Pull the stick out carefully.
    • In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
Conclusão
7 outras pessoas executaram este guia.
Kevin Rehm
Membro desde: 04/19/10
472 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 29-76, Johann Spring 2010 Membro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membros
Autoria de 37 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 7,268
