Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The Mini-PCI port can be accessed easily after removing the rear cover
O que você precisa
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully disconnect it from the motherboard and pull it out of the device.
Uma outra pessoa concluiu este guia.
