Pular para o conteúdo principal
Introdução
The Mini-PCI port can be accessed easily after removing the rear cover
Peças
Nenhum componente especificado.
  1. Unscrew the 20 Phillips screws on the underside of the T42.
    • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
  2. Unscrew the 2 Phillips screws on both sides of the T42's rear.
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
  3. Flip the laptop over and open the screen.
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  4. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together. Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  6. Remove the screw affixing the bracket down.
    • Remove the screw affixing the bracket down.
  7. Lift the bracket up and out.
    • Lift the bracket up and out.
  8. Carefully disconnect it from the motherboard and pull it out of the device.
    • Carefully disconnect it from the motherboard and pull it out of the device.
Conclusão
Gerald Watanabe
Membro desde: 14-04-2010
198 reputação
7 Guias de autoria
Equipe
Cal Poly, Team 29-76, Johann Spring 2010 Membro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membros
30 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Todo: 4,057
