Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
3 outras pessoas executaram este guia.
