Introdução
Replacing the Hard Drive
O que você precisa
Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
Carefully grab the battery, then pull it straight out, not at an angle.
Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
7 outras pessoas executaram este guia.
