Ir para o conteúdo principal
IBM ThinkPad T42 Hard Drive Replacement
O que você precisa
  1. IBM ThinkPad T42 Hard Drive Replacement, Battery Clips: passo 1, imagem 1 %32
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 Hard Drive Replacement, Removing the Battery: passo 2, imagem 1 %32
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 Hard Drive Replacement, Hard Drive Screw: passo 3, imagem 1 %32
    • Unscrew the single screw holding the drive cage in place.
  4. IBM ThinkPad T42 Hard Drive Replacement, Sliding Drive Out: passo 4, imagem 1 %32
    • Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
    • It might help to open the display slightly.
  5. IBM ThinkPad T42 Hard Drive Replacement, Removal of HDD: passo 5, imagem 1 %32
    • Pull the Hard Drive out and proceed with replacement.
Conclusão
7 outras pessoas executaram este guia.
Austin Kidd
Membro desde: 04/21/10
317 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 29-76, Johann Spring 2010 Membro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
Membros da 4
Autoria de 35 guias
Um comentário
Excelente guía. Gracias
Luis Aguilar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 107
Duração total: 20,706
