Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replacing the fan.
O que você precisa
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
Unscrew the 3 screws on the copper heatsink.
Now, unplug the connection to the motherboard..
8 outras pessoas executaram este guia.
2 comentários
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
