Introdução
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its speakers.
O que você precisa
Close the screen and turn the closed laptop over.
Remove all 17 screws on the bottom of the computer.
The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
Close the laptop and turn it over.
Remove the five plastic stickers covering the screws on the front edge of the case.
Lift the speakers out by starting with the left end and then unsnake the wires.
