Ir para o conteúdo principal
Introdução
This simple repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its RAM.
Peças
Nenhum componente especificado.
  1. Close the screen and turn the closed laptop over.
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. Remove the extra RAM cover, by lifting where the screw was and pulling out.
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. Turn the laptop right side up and open the screen.
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. Push apart the retaining clips on the RAM.
    • Push apart the retaining clips on the RAM.
    • Note: The RAM should pop up a little bit.
  6. Lift out the RAM chip.
    • Lift out the RAM chip.
Conclusão
3 outras pessoas concluíram este guia.
Marissa Blustein
Membro desde: 16/04/2010
490 Reputação
12 Guias de autoria
Equipe
Cal Poly, Team 7-8, Maness Spring 2010 Membro de Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Membros
26 Guias de autoria
Um comentário
You only need to take out 4 screws on the bottom of the laptop that have a picture of a keyboard beside them to remove the keyboard. I don’t know why the tutorial says to take out all the screws. Other than that, great article.
Gary Thurman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 6,907
