Introdução
Use this guide to replace your wireless card.
O que você precisa
Flip the ThinkPad upside down with the bottom facing you.
Slide the latch to the right into the unlock position.
While holding the latch in the unlock position, lift the battery out with your other hand.
Focus on the panel at the center of the Thinkpad.
Unscrew the three 4mm Phillips #0 screws that bind the panel cover to the Thinkpad.
Lift the panel from the right edge and remove the panel.
Before removing the wireless card, identify the three wires that need to be removed.
The first two wires that are on the bottom right can be easily unplugged with your fingers by pulling on the white label that comes with the wire.
For the last wire on the center right, use a plastic opening tool to pry out the wire.
Um comentário
I f i take out this component will the computer act normally The computer has a car diagnostic program installed as an after thought as i wish to be normal computer Do i just remove and ever thing okay thanks Terry
