Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
IBM ThinkPad T30 Hard Drive Replacement
O que você precisa
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • Flip to the back of the Thinkpad and focus on the screw in the bottom left corner of the Thinkpad.
    • Unscrew the 11mm Phillips #0 screw.
  3. IBM ThinkPad T30 Hard Drive Replacement: passo 3, imagem 1 %32 IBM ThinkPad T30 Hard Drive Replacement: passo 3, imagem 2 %32 IBM ThinkPad T30 Hard Drive Replacement: passo 3, imagem 3 %32
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Use your thumbs to push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
  4. IBM ThinkPad T30 Hard Drive Replacement: passo 4, imagem 1 %32 IBM ThinkPad T30 Hard Drive Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to remove the black plastic cover from the main body of the hard drive. Pry on the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
  5. IBM ThinkPad T30 Hard Drive Replacement: passo 5, imagem 1 %32 IBM ThinkPad T30 Hard Drive Replacement: passo 5, imagem 2 %32
    • Locate and remove the four 2.8mm Phillips #0 screws on the mounting bracket.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
Conclusão
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
11 outras pessoas executaram este guia.
Allie Knauer
Membro desde: 10/05/12
90 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-20, Amido Fall 2012 Membro de Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
Membros da 3
Autoria de 16 guias
Um comentário
good description and photos..thanks :]
David - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 62
Duração total: 19,014
