Ir para o conteúdo principal
IBM ThinkPad R40 Fan Replacement
O que você precisa
  1. IBM ThinkPad R40 Fan Replacement, Fan: passo 1, imagem 1 %32
    • Remove the screws shown. These screws are connected to the keyboard.
  2. IBM ThinkPad R40 Fan Replacement: passo 2, imagem 1 %32
    • Take the spudger tool, go around the edges of the oranges boxes shown, and pop off those two sections. Then, go around the edges of the keyboard, and it should slide off.
  3. IBM ThinkPad R40 Fan Replacement: passo 3, imagem 1 %32 IBM ThinkPad R40 Fan Replacement: passo 3, imagem 2 %32
    • Lift and move keyboard aside to get to screws. Try not to remove the attached ribbon.
    • Remove the screws shown. These screws will allow you to loosen the fan. Be careful since there is still another part connected.
  4. IBM ThinkPad R40 Fan Replacement: passo 4, imagem 1 %32
    • Carefully unplug the highlighted part, and your fan should come straight out.
  5. IBM ThinkPad R40 Fan Replacement: passo 5, imagem 1 %32
    • The section in blue is where your new fan will go.
Conclusão
5 outras pessoas executaram este guia.
Aaron
Membro desde: 03/12/14
134 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-2, Vijaybhaskar Spring 2014 Membro de UMass Dartmouth, Team 2-2, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S2G2
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 2,855
