Peças
Não são necessárias peças.
  1. Flip the ThinkPad over so that it is upside down. Push latch switch to the left.
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  2. The sticker is to keep the warranty on the laptop so once removed the warranty is void Peel the sticker and remove the 15mm screw Remove all 6 of the 16mm screws
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. use a  prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  5. Lift the keyboard and remove the keyboard ribbon cable  from the laptop Lift the keyboard and remove the keyboard ribbon cable  from the laptop Lift the keyboard and remove the keyboard ribbon cable  from the laptop
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
Conclusão
2 outras pessoas concluíram este guia.
Matheus
128 reputação
Autoria de 1 guia
Equipe
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Todo: 84
