Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Flip the ThinkPad over so that it is upside down. Push latch switch to the left.
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Remove the 6mm screw Pull out the hard drive The hard drive might be a little tough to pull out
    • Remove the 6mm screw
    • Pull out the hard drive
    • The hard drive might be a little tough to pull out
Conclusão
Uma outra pessoa concluiu este guia.
Thomas Stone
Membro desde: 19-03-2018
235 reputação
2 Guias de autoria
Equipe
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Todo: 184
