Ir para o conteúdo principal
IBM ThinkPad A31 Display Replacement
O que você precisa
  1. IBM ThinkPad A31 Display Replacement, Keyboard: passo 1, imagem 1 %32 IBM ThinkPad A31 Display Replacement, Keyboard: passo 1, imagem 2 %32 IBM ThinkPad A31 Display Replacement, Keyboard: passo 1, imagem 3 %32
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  2. IBM ThinkPad A31 Display Replacement: passo 2, imagem 1 %32 IBM ThinkPad A31 Display Replacement: passo 2, imagem 2 %32
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  3. IBM ThinkPad A31 Display Replacement: passo 3, imagem 1 %32 IBM ThinkPad A31 Display Replacement: passo 3, imagem 2 %32 IBM ThinkPad A31 Display Replacement: passo 3, imagem 3 %32
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  4. IBM ThinkPad A31 Display Replacement, Display: passo 4, imagem 1 %32 IBM ThinkPad A31 Display Replacement, Display: passo 4, imagem 2 %32
    • Remove the one 21mm screw
    • Remove the 6mm screw
  5. IBM ThinkPad A31 Display Replacement: passo 5, imagem 1 %32 IBM ThinkPad A31 Display Replacement: passo 5, imagem 2 %32
    • Take the tool and run it under the black case.
  6. IBM ThinkPad A31 Display Replacement: passo 6, imagem 1 %32 IBM ThinkPad A31 Display Replacement: passo 6, imagem 2 %32 IBM ThinkPad A31 Display Replacement: passo 6, imagem 3 %32
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  7. IBM ThinkPad A31 Display Replacement: passo 7, imagem 1 %32 IBM ThinkPad A31 Display Replacement: passo 7, imagem 2 %32
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  8. IBM ThinkPad A31 Display Replacement: passo 8, imagem 1 %32 IBM ThinkPad A31 Display Replacement: passo 8, imagem 2 %32 IBM ThinkPad A31 Display Replacement: passo 8, imagem 3 %32
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
Conclusão
Sean Tocci
Membro desde: 03/19/18
293 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 Membro de UMass Dartmouth, Team S2-G2, Bernier Spring 2018
UMASSD-BERNIER-S18S2G2
Membros da 3
Autoria de 10 guias
Um comentário
i have that but display is
not work
Ahmed Elwy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 486
