Ir para o conteúdo principal
IBM ThinkPad A31 CPU Replacement
O que você precisa
  1. IBM ThinkPad A31 CPU Replacement, Hard Drive: passo 1, imagem 1 %32 IBM ThinkPad A31 CPU Replacement, Hard Drive: passo 1, imagem 2 %32 IBM ThinkPad A31 CPU Replacement, Hard Drive: passo 1, imagem 3 %32
    • Remove the 6mm screw
    • Pull out the hard drive
    • The hard drive might be a little tough to pull out
  2. IBM ThinkPad A31 CPU Replacement, Keyboard: passo 2, imagem 1 %32 IBM ThinkPad A31 CPU Replacement, Keyboard: passo 2, imagem 2 %32 IBM ThinkPad A31 CPU Replacement, Keyboard: passo 2, imagem 3 %32
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. IBM ThinkPad A31 CPU Replacement: passo 3, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 3, imagem 2 %32
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  4. IBM ThinkPad A31 CPU Replacement: passo 4, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 4, imagem 2 %32 IBM ThinkPad A31 CPU Replacement: passo 4, imagem 3 %32
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  5. IBM ThinkPad A31 CPU Replacement, Display: passo 5, imagem 1 %32 IBM ThinkPad A31 CPU Replacement, Display: passo 5, imagem 2 %32
    • Remove the one 21mm screw
  6. IBM ThinkPad A31 CPU Replacement: passo 6, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 6, imagem 2 %32
    • Take the tool and run it under the black case.
  7. IBM ThinkPad A31 CPU Replacement: passo 7, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 7, imagem 2 %32 IBM ThinkPad A31 CPU Replacement: passo 7, imagem 3 %32
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  8. IBM ThinkPad A31 CPU Replacement: passo 8, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 8, imagem 2 %32
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  9. IBM ThinkPad A31 CPU Replacement: passo 9, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 9, imagem 2 %32 IBM ThinkPad A31 CPU Replacement: passo 9, imagem 3 %32
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
  10. IBM ThinkPad A31 CPU Replacement, Battery: passo 10, imagem 1 %32 IBM ThinkPad A31 CPU Replacement, Battery: passo 10, imagem 2 %32
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  11. IBM ThinkPad A31 CPU Replacement, CPU: passo 11, imagem 1 %32 IBM ThinkPad A31 CPU Replacement, CPU: passo 11, imagem 2 %32 IBM ThinkPad A31 CPU Replacement, CPU: passo 11, imagem 3 %32
    • LIft the bracket out
  12. IBM ThinkPad A31 CPU Replacement: passo 12, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 12, imagem 2 %32 IBM ThinkPad A31 CPU Replacement: passo 12, imagem 3 %32
    • Remove one 6mm screw
    • Remove 3 18mm screws
    • Take off the bracket on the CPU fan
  13. IBM ThinkPad A31 CPU Replacement: passo 13, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 13, imagem 2 %32 IBM ThinkPad A31 CPU Replacement: passo 13, imagem 3 %32
    • Lift the CPU fan
    • Pull out the cable attached to the motherboard
  14. IBM ThinkPad A31 CPU Replacement: passo 14, imagem 1 %32 IBM ThinkPad A31 CPU Replacement: passo 14, imagem 2 %32
    • Turn the locking screw to unlock with the flat head screwdriver
    • LIft the CPU out
Conclusão
Uma outra pessoa concluiu este guia.
Thomas Stone
Membro desde: 03/19/18
235 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 Membro de UMass Dartmouth, Team S2-G2, Bernier Spring 2018
UMASSD-BERNIER-S18S2G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 937
